TextPropertyExtractor
Extracts the values of text attributes from input text geometry features.
Name of the attribute that is set to the value of the input text geometry feature's fme_text_string text attribute.
Name of the attribute that is set to the value of the input text geometry feature's fme_text_size text attribute.
Name of the attribute that is set to the value of the input text geometry feature's fme_rotation text attribute.
Transformer Categories
Search FME Knowledge Center
