PointCloudSplitter
Multiple point-cloud features as specified by the Split By parameter.
Specifies the component(s) on which the point cloud will be split. This may be any single component name, or one of the following special values:
Color: The point cloud will be split on the color_red, color_green, and color_blue components.
First Return Only: One point cloud feature is output containing all the points whose return number is 1.
Last Return Only: One point cloud feature is output containing all the points which represent the last return (that is, where the return number is equal to the number of returns).
Specifies whether to split by unique values or ranges. When splitting by unique values, one point cloud will be output for each unique value of the specified component found in the point cloud. When splitting by ranges, one point cloud will be output for each specified range of values, provided at least one point falls in the range.
If Split Type is set to Range, this attribute will be set to the output value specified in the range list corresponding to each output point cloud.
If Split Type is set to Unique, this attribute will be set to the value of the component for each output point cloud.
If Split By is set to Last Return Only, this attribute will contain -1, since the last return value can vary from point to point.
When splitting by ranges, this parameter specifies the ranges to keep.
- From: The start value for the range that you are classifying. This field accepts numerical input only and must be less than the value in the To field. Colors should be specified as comma-delimited values (for example, 255,100,50). If a From value is not specified, it will be treated as an open-ended range.
- To: The end value for the range that you are classifying. This field accepts numerical input only and must be less than the value in the To field. Colors should be specified as comma-delimited values (for example, 255,100,50). If a To value is not specified, it will be treated as an open-ended range.
- Output Value: The value assigned to the output attribute for each range.
When splitting by unique values to keep, this which values should actually be kept. Values not included in this list will be discarded. Limiting a splitting operation to only desired values will improve performance.
Transformer Categories
Search FME Knowledge Center
Tags Keywords: point "point cloud" cloud PointCloud split filter LiDAR sonar
