Sets the given attributes to the properties of an arc geometry. This transformer works on a single feature at a time.
 Input
Input
                                            Features with arc geometry.
 Output
Output
                                            Features with given attributes set to the properties of the arc geometry.
 Primary Radius Attribute
                                            Attribute name that is set to the length of the primary radius for the ellipse upon which the arc is based.
 Secondary Radius Attribute
                                            Attribute name that is set to the length of the secondary radius for the ellipse upon which the arc is based.
 Rotation Attribute
Rotation Attribute
                                            Attribute name that is set to the rotation of the ellipse that defines the arc. The rotation angle specifies the angle in degrees from the horizontal axis to the primary axis in a counterclockwise direction.
 Start Angle Attribute
                                            Attribute name that is set to the parametric angle of the start point of the arc, in degrees.
 Sweep Angle Attribute
                                            Attribute name that is set to the parametric sweep angle of the arc, in degrees.
 Start X Attribute
Start X Attribute
                                            Attribute name that is set to the x coordinate value for the arc’s start point
 Start Y Attribute
Start Y Attribute
                                            Attribute name that is set to the y coordinate value for the arc’s start point
 Start Z Attribute
Start Z Attribute
                                            Attribute name that is set to the z coordinate value for the arc’s start point
 End X Attribute
End X Attribute
                                            Attribute name that is set to the x coordinate value for the arc’s end point
 End Y Attribute
End Y Attribute
                                            Attribute name that is set to the y coordinate value for the arc’s end point
 End Z Attribute
End Z Attribute
                                            Attribute name that is set to the z coordinate value for the arc’s end point
 Center X Attribute
Center X Attribute
                                            Attribute name that is set to the X coordinate of the center of the ellipse. If not specified, the first coordinate of the feature is used.
 Center Y Attribute
Center Y Attribute
                                            Attribute name that is set to the Y coordinate of the center of the ellipse. If not specified, the first coordinate of the feature is used.
 Center Z Attribute
Center Z Attribute
                                            Attribute name that is set to the Z coordinate of the center of the ellipse. If not specified, the first coordinate of the feature is used.
Using a set of menu options, transformer parameters can be assigned by referencing other elements in the workspace. More advanced functions, such as an advanced editor and an arithmetic editor, are also available in some transformers. To access a menu of these options, click  beside the applicable parameter. For more information, see Transformer Parameter Menu Options.
Transformer Categories
Search FME Knowledge Center
