You are here: Infrastructure > PythonCreator
PythonCreator
Creates features using the Python script supplied, and sends them into the workspace for processing. The Python script must be in the form of a Python class, with the code responsible for creating the features located in the close() method.
Features are created via the FME Objects Python API. To view the API documentation, navigate to your FME installation folder and go to this location: fmeobjects\python\apidoc\index.html.
Example Class
The example below creates a random number of features, between 0 and 9.
import fmeobjects
import random
class FeatureCreator(object):
def __init__(self):
self.number = random.random()
def close(self):
for i in range(1, int(self.number*10)):
feature = fmeobjects.FMEFeature()
feature.setAttribute("feature_count", i)
self.pyoutput(feature)
Script Editing
A PythonCreator transformer can call scripts stored in the transformer itself or stored globally for the entire workspace:
  • To store a Python script with a specific PythonCreator transformer, use the “Python Script” property of the transformer.
  • To store a Python script globally, click the Advanced Workspace Parameter in the Navigator, and double-click Startup Python Script. Storing scripts globally has the advantage of keeping your Python logic centralized, which makes editing and maintenance easier. This is useful if you want to have multiple PythonCreator transformers throughout your workspace that use the same script.
If you are using extensive Python libraries that you do not want to store inside a workspace: to avoid duplication, you can access .py files on the file system using Python’s import command. In addition to the standard Python module locations, FME will also search the location of the workspace for an imported Python module.
Transformer Categories
Infrastructure
Dependencies
An FME installation includes a Python interpreter, which is used by default for all Python processing.
FME 2012 ships with Python version 2.7. The FME Objects Python API supports Python 2.5 to 2.7.
To choose a different Python interpreter for FME, change the FME Options:
  • Select Tools > FME Options, and click the Runtime icon:
  • Under Python Interpreter, check the box Use Custom Python Interpreter.
  • Browse to the location of the Python DLL that you wish to use (for example, python26.dll).
  • Click OK to save the changes.
FME Licensing Level
Search FME Knowledge Center
