RasterToPolygonCoercer
Creates polygons from input raster features. One polygon is output for each contiguous area of pixels with the same value in the input raster.
Specifies whether polygons will be output for nodata areas in the raster.
A cell is considered to be nodata when, for each selected band, the value for that cell is equal to that band's nodata value. If any cell value is not equal to that band's nodata value, the cell will be considered data.
Specifies whether the output vector features should retain attributes from the input raster feature.
Specifies the name of an attribute that will be created on every output feature describing the polygon.
The label will be a comma-separated list of the band values covered by that polygon. For example, the label for a raster with three bands might be something like 64,128,255.
Transformer Categories
FME Licensing Level
Search FME Knowledge Center
