RasterBandOrderer
Specifies the order of bands in a raster. Bands are reordered according to the input band indices.
This parameter is a list of band indices separated by spaces. It specifies the desired order of the bands. Indices are zero-based, so the first band is at index 0.
Bands in the original raster that are not specified in the string will be appended after all the specified bands, in their original order. Note that bands may not be included in the list more than once.
For example, given an RGBA input raster with four bands and a band list of "3 0 2", the resulting raster would have bands ARBG.
Transformer Categories
FME Licensing Level
Search FME Knowledge Center
Tags Keywords: raster grid band order sort
