CharacterCodeExtractor
Extracts the integral character code of the first character in the source string attribute, and adds its integer value in the character set to the feature as another attribute.
This can be used to obtain the ASCII code of any character, including non-printable ones.
The attribute that contains the character for which you would like to find the equivalent numeric code
The name of the attribute that will store the resulting integer value.
Example
For example, a control-A character as the first character of the source string attribute would result in a value of 1 being placed in the character code attribute.
To obtain the character equivalent of a numeric value, use the CharacterEncoder transformer.
Transformer Categories
Search FME Knowledge Center
