RasterCellValueRounder
Rounds off raster cell values.
Note: Note that floating point decimal values usually cannot be exactly represented. For example, the value 727.27 may actually be represented as 727.27002 when stored as a 32-bit floating point value. This property of floating point numbers may cause unexpected results when writing to text-based formats such as ESRIASCIIGRID. To avoid this, consider coercing floating point bands to real64 before using this transformer.
Controls the number of decimal places to which the cell values are rounded.
A value of 0 causes the cell values to be rounded to the nearest integer. A value of 1 causes rounding to the nearest tenth. Negative values are allowed. A value of -1 causes rounding to the nearest 10.
Controls how the rounding will take place:
- Up: The cell values will always be rounded up.
- Down: The cell values will always be rounded down.
- Nearest (default): The cell values will be rounded up or down to the nearest value.
This transformer supports raster band selection.
The RasterSelector can be used to modify selection.
Transformer Categories
Search FME Knowledge Center
