RasterExtentsCoercer
Replaces the geometry of input raster features with a polygon covering the extents of the raster.
Raster Extents: The polygon covers the entire extents of the raster. If the raster is rotated, the rotated corners of the raster are used for the polygon.
Data MBR Extents and Data Extents: These modes examine the data in the raster to more accurately determine the extents. A cell is considered to be nodata when, for each selected band, the value for that cell is equal to that band's nodata value. If any cell value is not equal to that band's nodata value, the cell will be considered data. In these modes, this transformer will only operate on selected raster bands, and each selected band is required to have a nodata value.
In Data MBR Extents mode, the polygon will be an axis-aligned bounding rectangle that covers all data cells in the raster. This is more computationally expensive than finding the Raster Extents.
In Data Extents mode, the output geometry will be either a single polygon or an aggregate of polygons that exactly cover only the data cells in the raster. This is more computationally expensive than finding the Data MBR Extents.
Transformer Categories
FME Licensing Level
Search FME Knowledge Center
Tags Keywords: raster grid band channel vector spatial extent extract polygon vectorisation vectorization nodata footprint
