MGRSToLatLongConverter
Converts Military Grid Reference System (MGRS) code to longitude and latitude coordinates.
The ellipsoid used for the conversion. This can be any ellipsoid name supported by FME.
The type of lettering used can be WGS84 or Bessel.
An MGRS code used to convert to lat/long coordinates. You can choose this parameter from the list of attributes in the pull-down list, or enter an MGRS string.
The longitude and latitude values obtained from the MGRS code will be stored in the Longitude and Latitude attributes of the feature, respectively.
Transformer Categories
FME Licensing Level
Search FME Knowledge Center
