You are here: Infrastructure > FeatureColorSetter
FeatureColorSetter
Assigns colors to incoming features.
Mode
Example
In the example below, there are unique feature counts and then IDs.
If aggregates are not important, only 3 colors are required:
Feature Adjacent to Areas
2,20 1, 3, 6
8,20 3
9,20 4
If, however, ID 2,20 is treated as an aggregate, then 4 colors are required and the pre-existing ID attributes must be supplied.
20 10, 30, 40, 60
Feature Not Adjacent to Area
20 50
Related Transformers
  • A TopologyBuilder placed before the FeatureColorSetter can help you build a list of adjacent areas.
  • An AttributeFilter or another FeatureColorSetter can be used to manipulate the Color ID attribute.
Transformer Categories
Infrastructure
Transformer History
This transformer combines the features of, and replaces, these transformers: NeighborColorSetter, ColorSetter, RandomColorSetter.
Search FME Knowledge Center
Tags Keywords: AreaFillColorSetter AreaFillColourSetter PenColorSetter PenColourSetter ColorSetter ColourSetter FeatureColourSetter NeighborColorSetter NeighbourColourSetter NColorer NColourer MapColorer MapColourer MapColorizer MapColourizer RandomColorSetter RandomColourSetter
