RasterPaletteNodataSetter
Identifies the nodata value on a raster feature at the palette level.
The transformer will succeed in setting the specified nodata value only if the input raster band(s) have at least one palette and a nodata key has already been set on the band.
Input features must contain raster geometries only.
Features with the specified nodata value are output through this port.
A numeric value specifying the nodata value to be set on the palette. Multi-part interpretations (e.g. RGB) may be specified as a comma-delimited value (e.g. "10,20,30"). The original nodata value is discarded if it exists.
- RGB and RGBA color models are supported by this transformer.
- This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
Related Transformers
This transformer does not set the nodata value on the band level. To set the nodata value on the bands of a raster, use the RasterBandNodataSetter.
Transformer Categories
FME Licensing Level
Search FME Knowledge Center
Tags Keywords: raster grid band channel palette lookup LUT colormap colourmap null void value set modify flag
