AttributeDecompressor
Decompresses and decrypts the values of the specified attributes that were compressed by the AttributeCompressor.
Features with attributes that were compressed by the AttributeCompressor.
List of decompressed attributes.
Decompression Parameters
After connecting the transformer, click the browse button to select the attributes to Decompress.
The decompression/decryption algorithms produce a string of bytes. Use this parameter to instruct the transformer how to interpret those bytes. If an encoded attribute was compressed in the AttributeCompressor transformer, this parameter should be set to the same encoding.
Decryption Parameters
Use this parameter to select an encryption type. Currently, only the AES-256 encryption algorithm is supported.
If encryption is being used, the value of this parameter will be used to generate an encryption key. This must be the same value used to encrypt the attribute values in the AttributeCompressor transformer.
The AttributeDecompressor uses the zlib library to provide basic compression, and the OpenSSL library to provide encryption.
Transformer Categories
Search FME Knowledge Center
Tags Keywords: decompress compress zip zlib AttributeCompressor compressing decompressing
