You are here: Rasters > RasterGCPExtractor
RasterGCPExtractor
Extracts the coordinate system and the Ground Control Points (GCP) from the raster feature and exposes them as attributes.
Output
The output attribute of this transformer is encoded as follows:
pixel line x y z;pixel line x y z etc.
The following raster properties are exposed:
_gcp_coordsys
_gcp_value
None.
Transformer Categories
Rasters
FME Licensing Level
Search FME Knowledge Center
