KMLTimeSetter
Sets the time-related KML attributes for a group of features destined for the OGCKML Writer.
This parameter determines the type of KML time primitive that will be created. Possible options include Timestamp and Time Period.
This parameter specifies the value of the timestamp if the time type is Timestamp. The value can either be in the FME DateTime format, or the XML Schema time format.
This parameter specifies the beginning of the time period if TimePeriod is the selected time type. The value can either be in the FME DateTime format, or the XML Schema time format.
This parameter specifies the optional end of the time period if TimePeriod is the selected time type. The value can either be in the FME DateTime format, or the XML Schema time format.
Timestamp Settings
Time Period Settings
Additional References
For more information regarding KML time primitives:
- See the FME OGCKML Writer chapter in the FME Readers and Writers manual (in Workbench, select Help > FME Readers and Writers Reference)
- See the KML documentation: http://developers.google.com/kml/documentation/kml_tut
Transformer Categories
Search FME Knowledge Center
Tags Keywords: "Google Earth" KML
