You are here: Point Cloud > PointCloudExtractor
PointCloudExtractor
Serializes the geometry of the feature into the Blob Attribute based on the selected writer format.
  • The PointCloudReplacer may be used to do the reverse operation and convert the encoded blob back to the original data.
  • Alternatively if the point cloud is not required as a geometry on the feature for future processing, the AttributeFileWriter transformer can be used to dump the Blob Attribute directly to a file.
  • To carry out a similar operation on vector data, please use the GeometryExtractor transformer. For raster data, please use the RasterExtractor.
Transformer Categories
Point Cloud
Related Transformers
PointCloudReplacer
GeometryExtractor
GeometryReplacer
RasterExtractor
RasterReplacer
FME Licensing Level
Search FME Knowledge Center
