RasterConsumer
Requests the tile(s) from the raster geometry but no actual operations are performed on the tile(s).
All input features must have raster geometry.
Tile: The raster data is read one tile at a time until all tiles are consumed. Several bands may be read for a given tile.
Band: The raster data is read one band at a time until all bands are consumed.
Use source tile size: The default tile size reported by the band will be used when tiles or bands are consumed.
Specify source tile size: The raster will be consumed using the specified Number of Tile Rows and Number of Tile Columns.
In conjunction with Specify source tile size, specify the number of rows and columns.
- Tiles may be used to partition each band into manageable chunks. Some raster sources may perform better using different patterns.
- This transformer is unaffected by raster band and palette selection.
Transformer Categories
FME Licensing Level
Search FME Knowledge Center
