RasterGeoreferencer
Georeferences a raster using the specified parameters.
The Parameter Type determines which parameters are required in this transformer.
Parameter Type
Point And Angle: X Upper Left Coordinate, Y Upper Left Coordinate, X Cell Spacing, Y Cell Spacing and Rotation will be used.
In this case, the raster's origin will be set to the upper left coordinate and X Cell Spacing, Y Cell Spacing and Rotation are stored as input, untouched.
Extents: X Upper Left Coordinate, Y Upper Left Coordinate, X Upper Right Coordinate, Y Upper Right Coordinate, X Lower Right Coordinate, Y Lower Right Coordinate, X Lower Left Coordinate and Y Lower Left Coordinate will be used.
In this case, all input coordinates are validated to be unique, to form a rectangle which can be rotated, and to be clockwise. The rotation and spacing are then calculated from these coordinates and stored. The raster's origin will be set to the upper left coordinate.
- If the raster is already georeferenced, this will overwrite the old georeferencing information.
- This transformer is unaffected by raster band and palette selection.
Example
Transformer Categories
FME Licensing Level
Search FME Knowledge Center
