BoundingBoxReplacer
Replaces the geometry of the feature with either its two-dimensional bounding box or its two-dimensional minimum oriented bounding box.
If a feature’s bounding box has zero area, it will become a line or a point. If the feature was originally 3D, it will be set to 2D upon leaving, and the z values will be ignored and dropped.
Choose Bounding Box (which means the axis-aligned or rectilinear bounding box) or Oriented Bounding Box
Optionally, you can calculate the lengths of the shorter and longer sides of the chosen bounding box. They will appear as attributes in the Box output port.
Example
Related Transformers
- To accumulate the bounding box of a number of features, use the BoundingBoxAccumulator.
- To retrieve the bounds of a feature into attributes, use the BoundsExtractor.
- To replace the geometry of a feature with a box whose values come from attributes, use the 2DBoxReplacer.
Transformer Categories
Search FME Knowledge Center
Tags Keywords: MBR "minimum bounding rectangle" neatline "envelope oriented" "bounding box"
