2DArcReplacer
The 2DArcReplacer replaces the geometry of the feature with a two-dimensional arc whose shape is set by the parameters, which can be either constant floating point values or the values of existing attributes.
Output features with replaced arc geometries.
Each parameter may either be entered as a number, or taken from the value of a feature attribute by selecting the attribute name from the pull-down list.
The center x and y parameters set the origin of the arc. If these values are blank, and the input features are points, the existing feature x/y values will determine the center of the arcs. If the parameter values are blank, and the input features are not points, the operation is undefined.
The primary and secondary axis set the radii of the arc. Note that the primary axis need not be larger than the secondary, however, the rotation angle is always measured from the x axis to the primary axis. To make a circular arc, set both the primary and secondary axis to the same value.
The start angle controls where the arc begins, and is measured in degrees counterclockwise from horizontal.
The sweep angle controls the duration of the arc, and is measured in degrees. For a positive sweep angle, the arc will run counterclockwise beginning at the start angle, and ending at the sum of the start angle and the sweep angle.
The rotation angle is measured in degrees counterclockwise from horizontal, and measures the rotation of the primary axis from horizontal.
Example
If the parameters for the arc are not known and need to be calculated from a linear feature’s geometry, use the ArcEstimator.
Transformer Categories
Search FME Knowledge Center
