You are here: Rasters > RasterPaletteRemover
Removes the selected palette(s) of a raster. The palette's band retains the palette key, but the corresponding values are lost.
If the source band has no palettes, the raster remains unchanged.
None.
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
Related Transformers
RasterPaletteResolver: Removes the palettes from selected bands, and resolves band cell values with the corresponding palette values.
Transformer Categories
Rasters
FME Licensing Level
Technical History
Associated FME function or factory: @RemoveRasterPalettes
Search FME Knowledge Center
Tags Keywords: raster grid band channel palette lookup LUT colormap colourmap remove delete destroy
