AttributeRangeFilter
Performs a lookup on a range-based lookup table, and routes the feature to the appropriate output port. If the input attribute does not match any of the given ranges, the feature is routed to the <Unfiltered> port.
The feature type that contains the attributes you want to filter.
If the feature’s attribute has a value that does not match any of the given ranges, or the attribute is not present, the feature is output via the <Unfiltered> port.
When you connect the transformer to the feature type, the list of attributes will appear in a pull-down list. Choose the attribute from the list.
This table specifies a set a ranges and the port that a feature will be sent to if the Source Attribute value is within that range.
To automatically generate a set of ranges:
- Click the Generate button to start the generation wizard.
- Choose the minimum and maximum values of the attribute.
- Choose the number of ranges you would you want to generate. The ranges will be equally spaced between the specified minimum and maximum values.
- Select the Include Open-ended Ranges checkbox to create two additional ports for values that are smaller than the minimum value or larger than the maximum value.
It’s important to note that the ranges you create are inclusive and that the order in which they appear on the table matters. For example, suppose one range is from 10 to 20 and the next range is from 20 to 30. The number 20 can belong to both ranges because each range is inclusive, but the number will only be matched to the first range.
Each range has a From value and a To value. These values are inclusive, and each feature will be matched to the first range (in the order present in the table) that contains the value of that feature's Source Attribute. If either From or To is omitted, the range is open-ended; that is, it will match any value greater than (for From) or less than (for To) what is specified.
Transformer Categories
Related Transformers
Search FME Knowledge Center
Tags Keywords: LUT lookup look-up RangeFilter
