RasterBandAdder
Adds a new band to a raster. The added band will have the same value in all cells, and the same raster-level properties as other bands in the raster (that is, number of rows/columns, cell spacing, cell origin, etc.).
Input features must contain raster geometries only.
Features with the added band are output through this port.
Interpretation
This parameter specifies the desired interpretation for the added band, including data type and bit depth.
Data Values
This parameter specifies the value that will be used for all cells in the added band.
This parameter sets the nodata value for the band.
Transformer Categories
FME Licensing Level
Search FME Knowledge Center
Tags Keywords: raster band grid "add band" "adding band" create
