RasterGCPSetter
Sets the Ground Control Points (GCP) on a raster with the specified Column (pixel), Row (line), X Coordinate, Y Coordinate and Z Coordinate.
If the raster has already set GCPs, the old GCPs will be overwritten.
This parameter indicates the coordinate system that would be effective if the Ground Control Points were applied. This is not necessarily equivalent to the coordinate system of the feature.
A string value specifying the GCP(s). Each GCP is separated with a semicolon and each value of a 5-value GCP is separated by a space.
To set a GCP
- Set the source coordinate system.
- In GCP Value, you must enter 5 values, separated with a space: Column(pixel) Row(line) X-Coordinate Y-Coordinate Z-Coordinate. For example,
1 10 50 -20 0
- To set multiple GCPs, you can use a semicolon to separate each GCP. For example,
1 10 50 -2.5 0; 2 4 6 8 10; 1 2 3 4 5
Transformer Categories
FME Licensing Level
Search FME Knowledge Center
