RasterSubsetter
Reduces a raster to a subset of its original size. This is essentially a clipping operation using pixel bounds instead of ground coordinates.
These parameters specify the position in the input raster from which the subset will be taken.
These parameters specify the size of the subset in cells to be taken from the raster. They do not include any padding values. These values must be greater than 0 for the input to be valid.
The padding parameters specify how many rows and columns of padding in cells should be placed around the subset portion of the raster.
Transformer Categories
FME Licensing Level
Search FME Knowledge Center
Tags Keywords: raster grid band clip subset
