DMSCalculator
Calculates degrees, minutes, and seconds (DMS) from a decimal degrees value stored in an attribute.
Choose the source attribute that contains the decimal degrees value.
The resulting DMS values are stored in attributes that have these names.
If the decimal degrees value was negative, the resulting degrees value will be negative, but the minutes and seconds values will be positive.
Transformer Categories
Search FME Knowledge Center
Tags Keywords: latitude longitude degrees minutes seconds
