OffsetCurveGenerator
Offsets the segments of linear features, and if necessary, connects them using stroked arcs.
Only 2D linear features are supported as input. Self intersecting lines are not supported, and may produce unpredictable results. Other types of geometry will result in undefined behavior.
Each point in the output curve will be the specified offset, measured in ground units, away from the input linear geometry. The output ports Left and Right will produce offset curves on either side of the linear geometry.
This parameter, measures in ground units, specifies the distance by which the output curve is offset from the input curve.
This parameter, measured in degrees, controls the smoothness of the stroked arcs in the output offset curve. As this parameter decreases in value, the smoothness of the arc connectors increases.
Transformer Categories
Search FME Knowledge Center
Tags Keywords: BufferCurveGenerator
