ReprojectLengthCalculator
Converts a given distance from one coordinate system to another. The transformer calculates the reprojected length of a line starting at the first coordinate in the feature, with the given length and angle. Both the length and angle parameters are specified in the source coordinate system.
This transformer is useful for converting data such as text heights and widths that are measured in many systems in the destination coordinate system units.
Distance specified in source coordinate system coordinates.
Angle of distance in source coordinate system. The angle is measured counter clockwise from horizontal and is specified in degrees.
The name of the reader and writer coordinate systems.
The calculated value is put into the attribute specified by the Reprojected Length Attribute parameter.
Transformer Categories
Search FME Knowledge Center
