3DAffiner
Performs a 3D affine transformation on the coordinates of the feature.
An affine transformation preserves parallelism of lines and planes in geometry. That is, any lines or planes that were parallel before the transformation are parallel after the transformation. As well, if a number of points falling on a straight line or a plane are transformed, the resulting coordinates will fall on a straight line or plane in the new coordinate system.
Affine transformations include translations, rotations, scalings, and reflections.
This transformer only accepts features with 3D geometries. Arcs and ellipses will be stroked to lines and polygons (respectively) before undergoing the transformation.
The transformed features.
The transformation results in the x and y coordinates being modified by:
x' = Ax + By + Cz + D
y' = Ex + Fy + Gz + H
z' = Ix + Jy + Kz + L
Coefficients <A>, <F> and <K> must be non-zero.
You can enter parameters as a number, or choose them from the value of a feature attribute by selecting the attribute name from the pull-down list.
Transformer Categories
Search FME Knowledge Center
Tags Keywords: pointcloud
