HullReplacer
Replaces the geometry of the feature with a polygon representing its hull.
This transformer accepts both 2D and 3D features, but the z coordinates of 3D features will be ignored during the calculation of the hull. The convex hull of 3D features will be a polygon that uses unmodified 3D vertices from the input features. This may result in a polygon with varying z coordinates. For concave hulls, the resulting polygons are always 2D features.
Arcs and ellipses will be stroked prior to the calculation of the hull. Text features will be treated as points.
A feature representing the requested hull. Typically a polygon, but possibly a line or a point.
The Hull Type parameter can specify either a convex or a concave hull. A convex hull is a polygon where no interior angle is greater than 180 degrees. For a concave hull this restriction does not apply.
The convex hull is defined as the minimum enclosing convex polygon. In lay terms, the effect is similar to tightening a rubber band around the feature. Note that the convex hull may be a line or a point if the resulting polygon has an area of zero.
The concave hull, also known as the alpha hull, is calculated based on the Alpha Value parameter. It is possible for the concave hull to more closely represent the outline of a feature’s geometry than the convex hull can. The concave hull may consist of multiple donuts or polygons.
Concave Hull Parameters
When the Alpha Value parameter is specified, it is used in the alpha hull calculation directly; a larger number will generally produce larger areas. If a circle with a radius of Alpha Value ground units is able to pass between two points A and B of the feature without touching any other points of the feature, then the resulting hull will not directly connect A and B. Geometries that are farther away than Alpha Value from the rest of the geometries may be culled (removed) if they do not constitute a valid area on their own. It is possible that a null geometry will be returned if the specified alpha was too small for the spacing of the geometry.
When the Alpha Value parameter is not specified, an approximation to the optimal alpha, which is the smallest alpha that generates a single area, will be used to generate the concave hull. Concave hull generation works best with points, but line and area geometries will be accepted and converted to points if input.
Example
Transformer Categories
Transformer History
This transformer was previously named ConvexHullReplacer.
Search FME Knowledge Center
Tags Keywords: ConvexHullCreator ConvexHullReplacer
