CircularityCalculator
Calculates the "circularity" of an area feature, which indicates how elongated the feature is.
A value of 1 indicates that the feature is a perfect circle, and 0 indicates that it is a line.
Note that long, thin polygons may still have a fairly high circularity value if they curve around in a U-shape.
If the calculation geometry used is specified as CONVEX_HULL, the convex hull of the feature is used for the calculation; otherwise, the geometry of the feature (FEATURE_BOUNDARY) is used.
The value returned is: 4 * PI * area / (perimeter * perimeter)
The name of the attribute that will contain the angularity calculation.
Transformer Categories
Search FME Knowledge Center
