BulkAttributeRemover
Removes all attributes on incoming features that match a given regular expression. This transformer can be used to remove large numbers of attributes that have common naming.
See the StringSearcher for more information on regular expressions.
Features with attributes.
Features with attributes matching the specified regular expression removed.
A regular expression that specifies what string an attribute name needs to contain for it to be removed. For example, to remove AutoCAD format attributes from a feature, specify: ^autocad_.*
Whether to remove All Attributes or All Except FME Attributes. FME attributes are prepended with “fme_”.
- Use the AttributeRemover to remove selected individual attributes from a feature.
- Use the AttributeKeeper to keep selected individual attributes on a feature.
Transformer Categories
Additional Resources
Test regular expressions with the Regex Editor in the parameter menu.
Transformer History
This transformer replaces the AttributeExpressionRemover.
Search FME Knowledge Center
Tags Keywords: AttributeExpressionRemover
