RasterCellCoercer
                                        Decomposes all input numeric raster features into individual points or polygons. One vector feature is output for each cell in the band.
Points: one point feature will be created for each of the raster's cells, positioned at the cell's origin.
Polygons: polygon features will be output, each one covering one of the raster's cells.
Attributes: One feature will be output per cell in the raster. Band and palette values will be stored in attributes named _band{}.value and _band{}.palette{}.value. The output geometry will be 2D.
Z Values: One feature will be output per band per cell in the raster. The output geometry will be 3D, where the z value is the band value.
Specifies whether point features will be output for nodata cells in the raster. When set to yes, a point feature will be output for each nodata cell. When set to no, point features will not be output for nodata cells in the raster.
Specifies whether each point will retain the attributes from the input raster.
When specified, each point or polygon receives a raster ID and a band ID which correspond to the raster and band from which the vector feature originated.
When specified, each point or polygon receives a row and a column attribute, specifying the cell for which the feature was created. Row 0, Column 0 corresponds to the upper-left corner.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
When Extract Band Values is set to Z Values, each selected band must not contain a palette.
Example
Transformer Categories
FME Licensing Level
Transformer History
This transformer was previously known as the RasterToPointCoercer, RasterPointExtractor, or GridPointExtractor.
Search FME Knowledge Center
Tags Keywords: GridPointExtractor RasterPointExtractor RasterToPointCoercer
