AttributeCompressor
                                        Compresses and (optionally) encrypts the values of the specified attributes. The compressed and encrypted attribute values can be decompressed and decrypted using the AttributeDecompressor.
This transformer is particularly useful for compressing large blocks of XML, or geometry-storing attributes.
Features with attributes.
List of compressed attributes.
Compression Parameters
After connecting the transformer, click the browse button to select the attributes.
The value of this parameter controls the compression level which will be applied to the attributes. A value of 0 indicates that no compression should be used, while a value of 9 indicates that maximum compression should be used. The default value is 6.
Encryption Parameters
Use this parameter to select an encryption type. Currently, only the AES-256 encryption algorithm is supported.
If encryption is being used, the value of this parameter will be used to generate an encryption key. The same value may then be used to decrypt the attribute values in the AttributeDecompressor transformer.
The AttributeCompressor uses the zlib library to provide basic compression, and the OpenSSL library to provide encryption.
Transformer Categories
Search FME Knowledge Center
Tags Keywords: compress compression compressing zlib zip
