GeometryValidator Issues Table
Here is a listing of the possible information reported for each issue in the GeometryValidator issues table. If an attribute or trait name can have several values, the values are listed next to the same attribute or trait name.
Not every attribute or trait presented will be reported for every occurrence of an issue. For example, a table may contain a Not Fully Repaired entry for repair state:
| _issues{0}.repair_state | Not Fully Repaired |
If the geometry is fully repaired, a repair_state entry will not be present.
When issues arise on meshes, supplementary_info may contain information about which part of the original mesh had the issue:
| _issues{0}.supplementary_info{0} .details | Miscellaneous |
| _issues{0}.supplementary_info{0}.location.x | 1 |
| _issues{0}.supplementary_info{0} .location.y | 0 |
| _issues{0}.supplementary_info{0} .location.z | 0 |
| _issues{0}.supplementary_info{0}.original_part_index | 0 |
| _issues{0}.supplementary_info{1}.original_part_index | 1 |
Since this information is unique to meshes, it is presented at the top of this document, but is otherwise not presented in any of the tables below.
Contains NaN (Not a Number) or Infinity
Attributes
| _issues{0}.count | 1 |
| _issues{0}.issue_found | Contains NaNs or Infinities |
| _issues{0}.sub_issue{0}.count | 1 |
| _issues{0}.sub_issue{0}.details | Miscellaneous |
Traits
| _issues{0}.supplementary_info | Some part(s) will be removed on repair |
| _issues{0}.supplementary_info{0}.details | Miscellaneous |
Contains Null Geometry Parts
Attributes
| _issues{0}.issue_found | Contains Null Geometry Parts |
Traits
| _issues{0}.count | 2 |
Duplicate Consecutive Points
Attributes
| _issues{0}.count | 9 |
Duplicate Consecutive Points in 2D Duplicate Consecutive Points in 3D |
| _issues{0}.location_sample.x | 0 |
| _issues{0}.location_sample.y | 15 |
| _issues{0}.location_sample.z | 1 |
| _issues{0}.sub_issue{0}.count | 9 |
| _issues{0}.sub_issue{0}.location_sample.x | 0 |
| _issues{0}.sub_issue{0}.location_sample.y | 15 |
| _issues{0}.sub_issue{0}.location_sample.z | 1 |
Traits
Note that .count is a count of the total number of identical, consecutive coordinates. The minimum reported .count value is therefore 2.
| _issues{0}.supplementary_info{0}.count | 2 |
| _issues{0}.supplementary_info{0}.location.x | 0 |
| _issues{0}.supplementary_info{0}.location.y | 15 |
| _issues{0}.supplementary_info{0}.location.z | 1 |
| _issues{0}.supplementary_info{1}.count | 3 |
| _issues{0}.supplementary_info{1}.details | Miscellaneous |
| _issues{0}.supplementary_info{1}.location.x | 5 |
| _issues{0}.supplementary_info{1}.location.y | 5 |
| _issues{0}.supplementary_info{1}.location.z | 5 |
| _issues{0}.supplementary_info{2}.count | 2 |
| _issues{0}.supplementary_info{2}.details | Miscellaneous |
| _issues{0}.supplementary_info{2}.location.x | 1 |
| _issues{0}.supplementary_info{2}.location.y | 2 |
| _issues{0}.supplementary_info{2}.location.z | 2 |
| _issues{0}.supplementary_info{3}.count | 2 |
| _issues{0}.supplementary_info{3}.details | Miscellaneous |
| _issues{0}.supplementary_info{3}.location.x | 0 |
| _issues{0}.supplementary_info{3}.location.y | 15 |
| _issues{0}.supplementary_info{3}.location.z | 1 |
Degenerate or Corrupt Geometries
Attributes
| _issues{0}.issue_found | Degenerate or Corrupt Geometries |
| _issues{0}.sub_issue.location.z | 15 |
| _issues{0}.sub_issue{0}.details | Explicit end point locations are too far from the parameter-defined arc. |
| _issues{0}.sub_issue{0}.location.x | 0 |
| _issues{0}.sub_issue{0}.location.y | 15 |
| _issues{0}.sub_issue{0}.location.z | 15 |
Traits
Self-Intersections in 2D
Attributes for Self-Intersected Geometries
| _issues{0}.issue_found | Self-Intersections in 2D |
| _issues{0}.sub_issue{0}.location.z | 1 |
Attributes for Remnants
| _issues{0}.repair_state | Remnant |
Traits for Self-Intersected Geometries
| _issues{0}.count | 4 |
| _issues{0}.supplementary_info{1}.location.z | 2 |
| _issues{0}.supplementary_info{2}.location.z | 1 |
| _issues{0}.supplementary_info{3}.location.z | 0 |
Traits for Remnants
| _issues{0}.supplementary_info{0} | Miscellaneous |
Non-Planar Surfaces
Attributes
| _issues{0}.issue_found | Non-Planar Surfaces |
Traits
Invalid Solid Boundaries
Attributes
| _issues{0}.issue_found | Invalid Solid Boundaries |
| _issues{0}.issue_found.sub_issue{0}.count | 1 |
| _issues{0}.issue_found.sub_issue{0}.details | Dangling faces |
Traits
Invalid Solid Voids
Attributes
| _issues{0}.issue_found | Invalid Solid Voids |
| _issues{0}.sub_issue{0}.details | Invalid Solid Boundaries |
Traits
Fails OGC Simple
Attributes
| _issues{0}.issue_found | Fails OGC Simple |
Traits
Fails OGC Valid
Attributes
| _issues{0}.issue_found | Fails OGC Valid |
| _issues{0}. sub_issue{0}.details |
| _issues{0}. sub_issue{0}.location_sample.x | 0 |
| _issues{0}. sub_issue{0}.location_sample.y | 15 |
| _issues{0}. sub_issue{0}.location_sample.z | 1 |
| _issues{0}.supplementary_info{0}.details | Inconsistent Orientation |
Traits
Missing Texture Coordinates
Attributes
| _issues{0}.count | 3 |
| _issues{0}.issue_found | Missing Texture Coordinates |
| _issues{0}.location_sample.z | 0 |
| _issues{0}.sub_issue{0}.location_sample.z | 0 |
Traits
| _issues{0}.supplementary_info{0}.location.z | 0 |
| _issues{0}.supplementary_info{1}.location.x | 1 |
| _issues{0}.supplementary_info{1}.location.y | 13 |
| _issues{0}.supplementary_info{1}.location.z | 0 |
| _issues{0}.supplementary_info{2}.location.x | 2 |
| _issues{0}.supplementary_info{2}.location.y | 12 |
| _issues{0}.supplementary_info{2}.location.z | 3 |
Missing Vertex Normals
Attributes
| _issues{0}.issue_found | Missing Vertex Normals |
Traits
| _issues{0}.location.x | 0 |
| _issues{0}.location.y | 15 |
| _issues{0}.location.z | 0 |
Invalid Area Orientation
Attributes
| _issues{0}.issue_found | Incorrect Orientation |
Traits
