You are here: StringsStringReplacer
StringReplacer
Replaces substrings matching a string or regular expression in the string contained in the source attribute.
In this example, a pure substitution of text is made without any use of regular expression functionality. This is the simplest kind of substring replacement.
   Source String: Bobby
   Text to Find: obb
   Replacement Text: ill
   Use Regular Expression: no
   Case Sensitive: yes
   Result: Billy
In this example, a pattern matching zero or more ’b’ characters is replaced with nothing.
   Text to Find: b*
   Replacement Text:
   Use Regular Expression: yes
   Case Sensitive: yes
   Result: Boy
In this example, a pattern matching zero or more ’b’ characters followed by a y is duplicated in the result (prepended by hyphens)
   Text to Find: b*y
   Replacement Text: --\\0-\\0
   Case Sensitive: yes
   Result: Bo--bby-bby
Related Transformers
See the StringSearcher transformer help for additional regular expression examples.
To replace pairs of substrings, use the StringPairReplacer transformer.
To search for regular expression matches in a string without doing any replacement, use the StringSearcher transformer.
Additional Resources
Test regular expressions with the Regex Editor in the parameter menu.
Transformer Categories
Strings
Search FME Knowledge Center
