You are here: ManipulatorsCoordinateSwapper
CoordinateSwapper
Swaps coordinate axes of the input features.
There are three common uses for this transformer:
  • The transformer was originally intended to help solve the problem of Lat/Long order, where some formats expect Latitude/Longitude, and others expected Longitude/Latitude.
  • The transformer can also be used to swap X or Y values with the Z axis to produce a cross-section view of a dataset, such as a building model elevation.
  • The transformer can also be used as a tool for quality assurance purposes, where switching the data into a different plane causes spikes in the other axes, like this:
Transformer Categories
Manipulators
Search FME Knowledge Center
Tags Keywords: transform transpose transposer switch
