You are here: CalculatorsStatisticsCalculator
Calculates statistics based on a designated attribute or set of attributes of the incoming features.
If a feature does not contain attributes with the specified names, or these attributes do not contain a valid number, then it will be treated as having an empty string value for each specified attribute. Numbers that begin with '0' will be treated as octal values. Numbers that begin with '0x' will be treated as hexadecimal values.
Transformer
Attributes to Analyze
Calculate Attributes
Example
Transformer Categories
Calculators
Search FME Knowledge Center
