Resamples an input raster using the desired dimensions, the desired cell size in ground units, or a percentage of the size.
Raster Size
 Size Specification
Size Specification
                                            To resize the input raster by dimensions, select RowsColumns.
To resize the input raster by cell size, select CellSize.
To resize the input raster by percentage, select Percentage.
 Number of Columns/Number of Rows
                                            Enter values when RowsColumns is selected.
 X Cell Spacing/Y Cell Spacing
                                            Enter values when CellSize is selected.
 Percentage
Percentage
                                            Specify a percentage. For example, if the input raster is 1000 rows by 800 columns and this is set to 50 percent, the resulting raster will be 500 rows by 400 columns.
Interpolation
 Interpolation Type
Interpolation Type
                                            Cell values are interpolated in order to change the raster to the specified size. You can choose from these interpolation methods.
Example
Using a set of menu options, transformer parameters can be assigned by referencing other elements in the workspace. More advanced functions, such as an advanced editor and an arithmetic editor, are also available in some transformers. To access a menu of these options, click  beside the applicable parameter. For more information, see Transformer Parameter Menu Options.
Transformer Categories
FME Licensing Level
Search FME Knowledge Center
Tags Keywords: raster grid band channel reproject resample upsample downsample "nearest neighbor" "nearest neighbour" bilinear bicubic average interpolate resize
