You are here: StringsCharacterCodeReplacer
Sets the result attribute to the 8-bit ASCII character whose numeric Unicode code was contained in the source code attribute (or the entered integer).
This can be used when the numeric Unicode code of any character is available, but the actual 8-bit ASCII character is desired. For example, if the source attribute had the value 1, a control-A character would be placed in the resulting string.
Transformer Categories
Strings
Related Transformers
To obtain the numeric code equivalent of a character, use the CharacterCodeExtractor transformer.
Transformer History
This transformer was previously named CharacterEncoder.
Search FME Knowledge Center
Tags Keywords: CharacterEncoder
