You are here: RastersRasterRotationApplier
Applies the raster rotation angle on the input raster properties to the rest of the raster properties and data values.
The expected input is a raster with a non-zero rotation angle and the expected output is a rotated raster with a rotation angle of 0.0.  It is expected that the input raster properties will be modified to conform the output raster properties for a raster rotated by the given angle.
Applying a rotation angle is primarily done for compatibility with other processing and writers that cannot handle a rotation angle.
  • This transformer is unaffected by raster band and palette selection.
  • It is suggested that the input raster also contain a nodata value since applying the rotation often has the effect of adding nodata areas around the corners of the rotated raster. These nodata areas will be filled with 0 or black values in the absence of an input raster nodata value.
Transformer Categories
Rasters
FME Licensing Level
Search FME Knowledge Center
Tags Keywords: raster grid band channel rotate rotation apply "nearest neighbor" "nearest neighbour" bilinear bicubic average interpolate
