Restructures and regroups incoming features based on specified “Group by attributes” and calculates summary statistics based on a designated “Attribute To Analyze” in order to form a Pivot table output.
Like its cousin, the StatisticsCalculator, the AttributePivoter groups features according to selected attributes, and computes statistics on a single attribute for all features in each group (Grouping by rows). Beyond this, the AttributePivoter allows for the order of these row grouping attributes to be specified so that a logical nesting of additional summary rows can be generated. In addition, the AttributePivoter also allows for new attributes to be generated dynamically based on the unique values of a selected attribute (Grouping by Column) with values populated by statistics performed on the resultant groupings.
Note: Note: Because the AttributePivoter generates attributes dynamically, you must set any writer feature types to dynamic mode if you want to include these attribute in the output. This is described in more detail in Result Grouping and Tabular Structure.
 Input
Input
                                            All features enter the transformer through the Input port.
 Data
Data
                                            A single new feature will be output containing all computed statistics for each completely defined row group. The attributes on these features are described in the “Result Grouping and Tabular Structure” section.
The first row emitted from the Data port will contain information to define the schema for a dynamically configured feature type.
 Summary
Summary
                                            For each logically nested grouping as described in the “Result Grouping and Tabular Structure” section, a summary row will be emitted prior to the first data row for the group. It provides summary information for all rows contained in the group. An overview summary of all rows will always be generated.
The first row emitted from the Summary port will contain information to define the schema for a dynamically configured feature type.
 Group Rows By
Group Rows By
                                            One or more attributes are chosen to specify how features are grouped to form the rows of the resulting table. Unlike most “group by” parameters, the user has the opportunity to specify the order of the grouping attributes, so that nested summary groupings can be generated, adding a hierarchical structure to the resulting table.
 Group Columns By
Group Columns By
                                            In addition to row groups, the user can optionally select an attribute whose unique values will generate new attributes, hence “pivoting” the data and further subdividing the groupings on which the statistics are calculated.
 Attribute to Analyze
                                            A single attribute is chosen upon which to compute statistics. The features are grouped according to the row and column grouping attributes, and statistics are calculated over all values of this attribute within the features in each group.
 Pivot Summary Statistic Types
                                            The user can choose to compute multiple types of summary statistics simultaneously. Each chosen statistic type will be represented as a separate column within each column group of the result table.
One or more of the following statistic types may be selected.
- Average: The statistical mean of all numeric values of the attribute to analyze, for all features in the group. Non-numeric values are not included in the result
- Count: The number of features in each group that has a value for the attribute to analyze.
- Minimum: The numerical minimum of all values of the attribute to analyze within the features of each group.
- Maximum: The numerical maximum minimum of all values of the attribute to analyze within the features of each group.
- Sum: The sum of all numeric values of the attribute to analyze, within each group.
 Row Group Summary Line Descriptor
                                            The section entitled “Result Grouping and Tabular Structure” defines a logical nesting of row groups. For each such logically nested group, the AttributePivoter computes summary statistics, which it emits as table rows through the Summary port. The value for the most specific row grouping attribute for the summary row is given a value of “<attrName> <description>”, where <attrName> is the name of the row grouping attribute, and <description> is the value given to the “Row Group Summary Line Description” parameter. For example, if grouping by the attribute “Region_RSS”, the summary row over all regions would have a value of “Region_RSS Total” for the “Region_RSS” attribute, assuming the row group summary line descriptor is left with the default value of “Total”.
Input features are grouped by “grouping attributes”, and statistics are computed on the specified analyzed attribute in each group. There are two kinds of grouping attributes which work together to define these groups:
- Row Grouping Attributes: The user specifies an ordered set of attributes that divide the statistics into rows. There is a single row of result data for each unique set of values for the specified set of row grouping attributes.
- Column Grouping Attribute: The user can optionally specify a single attribute to define columns in the resulting rows. If specified, each unique value of the column grouping attribute contributes a column of statistical data to the result, for each statistic being computed. Additionally, if there is more than one unique value for the column, a summary column will be generated for each statistic.
 If no column grouping attribute is selected, each row will contain a single computed result for each selected output statistic.
Because the row grouping attributes are ordered, they effect a sort of logical nesting of groups. At the lowest level, a complete set of unique values is represented as a single row of the result. One level up is the logical grouping consisting of the set of rows where all row grouping attributes are unique except for the last one specified. This logical nesting carries up to the first specified row grouping attributes.
A row resulting from a complete set of unique data values is known as a “data row”. There is an additional “summary row” generated for each logically nested grouping, which summarizes the data for the data rows contained in the grouping.
The sequence of resulting rows form a table with the following attributes:
- All of the row grouping attributes, whose combined values specify the actual group
- For each pivot summary type, an attribute with the corresponding statistic, computed over all features in the row group.
- If there was more than a single column group defined, each of the attributes in (2.) will be repeated for all column groups, along with a summary value (i.e. a “grand total”) computed over the attribute values over all column groups. The method for computing the summary value depends on the statistic it is representing:- Count and Sum statistics are summarized with the sum of the computed statistics for the row group.
- Average statistics are summarized with the average of all values in the row group.
- Min values are summarized by the minimum of all occurrences of the analyzed attribute for the group.
- Max values are summarized by the maximum of all occurrences of the analyzed attribute for the group.
The first data feature and first summary feature emitted will contain additional attributes which will contain the schema information needed to write the data out to a feature type configured for dynamic writing.
Example
 Creating pivot tables in FME
                                            Use AttributePivoter to create a simple pivot table, with the same contents as one created with Excel.
Source Table and Excel Pivot Table
Fictitious data generated in Excel was exported it to a CSV file for use in Workbench. A simple pivot table was also created in Excel to show what we want to produce from FME; basically we want to summarize observed values based on region and potential.
FME Pivot Table
The workspace shown below uses the AttributePivoter transformer to create statistics for the observed attribute, grouping features by region and potential. The new statistics features are written to a CSV file which has all of the same attributes/fields as the Excel pivot table. An additional CSV file is generated to hold the summary for each of the groups in the pivot table. Notice that the output feature types are both defined with dynamic schema; the schema actually comes from the schema information included in the first features emitted from the AttributePivoter’s Data and Summary ports at runtime.
The table written by FME and viewed in Excel resembles the Excel pivot table:
The summary table contains summary information for each group. It has the same schema as the result table above. The “region total” row contains the results for all data within the table.
Using a set of menu options, transformer parameters can be assigned by referencing other elements in the workspace. More advanced functions, such as an advanced editor and an arithmetic editor, are also available in some transformers. To access a menu of these options, click  beside the applicable parameter. For more information, see Transformer Parameter Menu Options.
Transformer Categories
Search FME Knowledge Center
