DonutBuilder
Cuts holes in polygonal features by making polygons completely enclosed in other polygons into holes of the containing polygon.
The DonutBuilder assumes that the input area features are topologically clean. Further, it is assumed that any two input polygons within a group either have a strict containment relationship, or are not overlapping.
Aggregate features are decomposed recursively to their components and non-area features will be output via the <Rejected> port.
The resulting donut and hole features will be output through this port.
Features with non-area or null geometry will be output through this port.
Rejected features will have an fme_rejection_code attribute with the value INVALID_GEOMETRY_TYPE.
Transformer
The default behavior is to use the entire set of input features as the group. This option allows you to select attributes that define which groups to form. Each set of features which have the same value for all of these attributes will be processed as an independent group.
Note: How parallel processing works with FME: see About Parallel Processing for detailed information.
This parameter determines whether or not the transformer should perform the work across parallel processes. If it is enabled, a process will be launched for each group specified by the Group By parameter.
Parallel Processing Levels
For example, on a quad-core machine, minimal parallelism will result in two simultaneous FME processes. Extreme parallelism on an 8-core machine would result in 16 simultaneous processes.
You can experiment with this feature and view the information in the Windows Task Manager and the Workbench Log window.
Yes: This transformer will process input groups in order. Changes on the value of the Group By parameter on the input stream will trigger batch processing on the currently accumulating group. This will improve overall speed if groups are large/complex, but could cause undesired behavior if input groups are not truly ordered.
No: This is the default behavior. Processing will only occur in this transformer once all input is present.
When viewed in 2D (ignoring Z), a path (which may define the border of a polygon) may appear to be closed as shown in the left figure below. This same path, when viewed in 3D, may appear to be open as shown in the right figure below.
| Mode | Description | Example |
| Extend | The Curve is extended so that all vertices are left at their original location. |
| Average | Subsequent vertices that are not connected, but share an x and a y value are combined into one vertex, whose Z value is the average of the original two. |
| First Wins | Subsequent vertices that are not connected, but share an x and a y value are combined into one vertex, whose Z value is taken from the first encountered vertex. |
| Last Wins | Subsequent vertices that are not connected, but share an x and a y value are combined into one vertex, whose Z value is taken from the last encountered vertex. |
| Ignore | Z values are ignored. No change is made to the way the nodes are connected. |
The Drop Holes parameter indicates whether or not features used to cut holes in containing features should themselves be dropped or output.
This parameter will be added to each output feature and will contain "yes" if that feature was used to cut a hole into some containing feature, and "no" if that feature was not used as a hole.
Area features may be considered in groups based on the value of one or more attributes. Only features in the same group are then considered for hole nesting.
Preserve Internal Edges (for advanced FME users) specifies that coordinate "cycles" within a polygon are allowable and will be preserved. A "cycle" is a line segment that occurs twice in the same polygon's boundary (once in each direction).
Attribute Accumulation
If Merge Hole is chosen, attributes from all features will be merged, and in case of conflicts, the value of the Conflict Resolution parameter will be used. If Prefix Hole is chosen, then all hole attributes will be presented with a prefix set in the Prefix parameter. If Only Use Hole is chosen, only attributes from hole features will be used.
This parameter is enabled when Accumulation Mode is set to Merge Hole. Use Outer Shell and Use Hole will give priority to outer shells and holes respectively in case of attribute conflicts.
The value is used as a prefix for hole attributes when Accumulation Mode is Prefix Hole.
If you specify a Hole List Name, a list will be created on each output donut containing an element for each input feature that became a hole, in the order that the holes appear on the donut.
Note: List attributes are not accessible from the output schema in Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. All list attribute transformers are displayed in the Contents pane of the Transformer Help under Lists. Alternatively, AttributeExposer can be used.
Example
Transformer Categories
Search FME Knowledge Center
Tags Keywords: island Donutizer
