3DForcer
Turns two-dimensional data into three-dimensional data by adding a z-value to every coordinate.
This transformer accepts any vector features. Features without 2D geometries will be unchanged.
Output features that have been converted to a three-dimensional form.
You can enter the parameter as a floating point number, or choose it from the value of a feature attribute by selecting the attribute name from the pull-down list.
If the feature was two-dimensional, it becomes three-dimensional with a constant elevation.
If No (default), the transformer overwrites all Z coordinates. If Yes, the transformer provides Z coordinates only to those features that do not have Z coordinates.
Note that the SurfaceDraper transformer (available in FME Professional and higher) can be used to supply interpolated elevation values to the vertices of 2D features based on a 3D grid or set of 3D features.
Transformer Categories
Search FME Knowledge Center
Tags Keywords: ElevationSetter
