You are here: Geometric OperatorsSpikeRemover
SpikeRemover
Cleans up feature geometries by removing spikes in 2D.
The transformer looks at every pair of line segments made up of three consecutive distinct points. If the angle (in degrees) between two line segments is less than or equal to the specified maximum angle, then the middle point is a spike and is removed.
If the geometry of a feature is a path, the transformer removes spikes between consecutive path segments as well. For a polygon or donut, if the start/end point is a spike, then it is also removed. The end result is still a polygon/donut. Any polygons, donuts, paths or lines that are part of a collection of geometry will also be processed.
The transformer will also remove any duplicate points.
The transformer is not effective when the line contains many deviations other than spikes. In such cases, it is recommended to first clean up the features using the Generalizer transformer with Douglas-Poiker algorithm.
Example
Transformer Categories
Geometric Operators
FME Licensing Level
Search FME Knowledge Center
