You are here: CalculatorsAreaCalculator
AreaCalculator
Calculates the area of a polygonal object and stores the value in an attribute. The area is calculated in square map units, whatever they are.
The type of area calculation that is performed is chosen by the Type parameter.
Transformer Categories
Calculators
Search FME Knowledge Center
Tags Keywords: Euclidean
