You are here: InfrastructureAttributeFileWriter
AttributeFileWriter
Writes the contents of the specified attribute to a file.
Note that if necessary, full pathnames can be created from existing attribute values by using the StringConcatenator to prepend folder names and/or append extensions prior to using this transformer. The resulting attribute can then be used to specify the target file name.
Transformer Categories
Infrastructure
Search FME Knowledge Center
