You are here: RastersRasterReplacer
RasterReplacer
Replaces the geometry of the feature with the geometry held in the Blob Attribute. The blob is decoded according to the selected raster format.
Note that this transformer only works with raster formats. Use the GeometryReplacer for vector formats or the PointCloudReplacer for point cloud formats.
Related Transformers
This transformer is typically used to restore a raster previously extracted into an attribute by the RasterExtractor.
GeometryExtractor
GeometryReplacer
PointCloudExtractor
PointCloudReplacer
Transformer Categories
Rasters
FME Licensing Level
Search FME Knowledge Center
Tags Keywords: raster geometry database extract replace blob serialize
