You are here: RastersRasterCellValueReplacer
Replaces a range of values in the source raster with a new single value.
  • This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
  • RGB and RGBA color models are not supported by this transformer.
  • Rasters that contain bands with palettes are not supported by this transformer.
Transformer Categories
Rasters
FME Licensing Level
Search FME Knowledge Center
