You are here: CalculatorsBoundsExtractor
BoundsExtractor
Extracts the minimum and maximum values of the feature’s coordinates into new attributes.
It determines the extreme values of the feature in each of the x and y (and optionally z) axes, and assigns these values to the resulting attribute names.
This transformer does not change the geometry of the original feature.
Example
As each feature enters the transformer, it has six new attributes added to it to hold the extents of the feature.
If a feature had the coordinates (1,10,100), (2,-20,150), then after leaving the transformer, it would have these new attributes with these values:
Attribute Value
_xmin 1
_xmax 2
_ymin -20
_ymax 10
_zmin 100
_zmax 150
Transformer Categories
Calculators
Related Transformers
Search FME Knowledge Center
Tags Keywords: MBR "minimum bounding rectangle" "neatline envelope" "Topfer index"
